Forward Controls to Footboards
Good info...thank you for posting this! I plan on installing them with the stock head pipe and heat shields! They will either fit or I'm gonna trade this sucker off for a Fat Boy! Thanks again!
They will work and you will love them.
The problem is they will not work with STOCK exhaust without modification. Several have installed them on WideGlides and Fatbobs by building "spacers" to move the exhaust side mounts out just a bit to clear the exhaust. Good luck with yours it will be worth the extra effort to get them on.
Finally found an Example I was looking for, check post #66.
https://www.hdforums.com/forum/dyna-...0500247-7.html
Hell...I'm not gonna go thru all that ****, so looks like I'm gonna trade it off! Too bad too, as I really like this Dyna! I just can't get my right leg to cooperate! Can't really get comfortable and that limits me to shorter rides! Getting too old I guess! Life is a b!tch...then ya get hit by one!
If already have forwads, then the worst part of the job is done (the taller shift arm is already installed). It's just a simple matter of bolting the forwards on to the bike, attaching the shifter spline, and the rear brake arm.
Maybe you are looking for a set of gently used Dyna rider forward controls at a big discount over new? If so, PM me, I just moved back to forwards from foot boards and I have them in a box.
I also think I saw where someone was just able to move the footboard mounts out with a simple spacer to make them work. Don't give up.
Agreed, don't get rid of a bike you really like. If nothing else Stock exhaust off of any dyna except Fatbob or 09'+ Wideglide will work and they are available cheap.
