Forward Controls to Footboards
#41
Update on my boards install - I got everything installed this week and took some pics for you all.
The install required modifications on both sides. On the right side I needed to cut away some of the heat shield on the exhaust to clear the read board mount. On the left side, I needed to grind away some of the shifter arm so that it wouldn't hit the primary cover when up shifting. That modification could have been avoided by removing the outer and inner primary cover and adjusting the tranny shift lever, but I didn't want to get into removing this inner cover - not something I wanted to undertake on this project. The other solution would have been to get a longer shift linkage. I will do that soon, and replace the shifter arm so that everything looks a little cleaner. But for now, it's all in and works great.
Here are some pics:
1. Modification to the shifter arm:
2. Left side installed:
3. Heat shield trimming:
4. Right side installed:
All in all, I'm really happy with how it turned out. They are really comfortable and I think look great too.
Here are some pics:
#42
Outch! Is that the shift link that came in the Kit? You must not have changed the shift leaver on the tranny then! Guess you didn't install the long rod in the kit either! I will be installing the kit from HD soon and am just thinking about having to do this! It is a FB with forwards! Any difference should be handled by the parts that are already there...I hope! Don't want open up another can of worms!
#43
#45
#46
#47
I decided against the Cross Backs 'cause of the close proximity to my right leg
with the crossover pipe under the AC cover! Perki...I think I have taken the first step down a very slippery slope here! I think the 2 into 1 is going to flow better and run lean! Next will come the obligatory Thunder Max and after market AC! Turns out to be one helluva expensive set of foot boards for my FB! I really didn't want to go down this road with THIS bike! On the other hand...why have a Harley parked in the garage that I can't ride further than 75 miles at a time! That's my max so far! What the hell...still cheaper than the Fat Boy...right!
#49
I'm confused as well. If he already had forwards, the shift lever should've stayed in the same position. I thought he already had forwards on the bike since that was his question in the OP. Either that or his linkage is different somehow.
#50
Here are some pics:
Here are some pics:
