Skull Battery Cover Band
Old 04-07-2007, 08:49 PM
Matrix's Avatar
Matrix
Matrix is offline
Default Skull Battery Cover Band
I want to replace the stock battery cover band and put a chrome skull battery cover band on it.
The new chrome one just sticks to the stock battery cover, after removing the stock band.
My question is has anyone put one on their Street Bob yet? Would you have a picture of it that you could post? The most important thing is did it stay secured with the tape alone to the wrinkle finish of the Street Bob battery cover?
I want to install the chrome one but I am very skeptical as to how well the adhesive tape will adhere to the wrinkle finish and I do not want the entire battery box to be chrome. I can't beleive that The MoCo couldn't make a battey cover band that secure to the battery cover better than this.
This is the cover band that I am looking at installing. This is just the trim band.
[IMG]local://upfiles/13379/7E3068CFD7364CE890CB590D1C338152.jpg[/IMG]
Old 04-07-2007, 08:56 PM
SWOOP_IN's Avatar
SWOOP_IN
SWOOP_IN is offline
Default RE: Skull Battery Cover Band
Ihave a band which installed the same way and I've had good luck so far. I have a painted gloss finish on my cover.
Old 04-07-2007, 08:58 PM
sjcope13's Avatar
sjcope13
sjcope13 is offline
It sticks to it fine. Make sure you clean the area with alcohol/water solution and also it should be a nice warm day. I forget what temp. they say it should be.
[IMG]local://upfiles/19982/166198AB8AA34ACDBC097A8092E22111.jpg[/IMG]
Old 04-07-2007, 09:02 PM
Matrix's Avatar
Matrix
Matrix is offline
ORIGINAL: SWOOP_IN
I would not have any doubt that it would stay secure if my battery box had a smoothe finish under the stock trim band but as luck would have it, the entire box is wrinkle finished.
Thanks
Old 04-07-2007, 09:05 PM
sjcope13's Avatar
sjcope13
sjcope13 is offline
I have the wrinkle finish on my box and it sticks fine. No problems.
Old 04-07-2007, 09:11 PM
SWOOP_IN's Avatar
SWOOP_IN
SWOOP_IN is offline
When I installed mine I did it in a climate controlled garage set at 68 degrees. The band I put on felt as if it wieghed 3 lbs. I did clean with rubbing alcohol first.
Old 04-07-2007, 09:56 PM
Matrix's Avatar
Matrix
Matrix is offline
Yep, my two concerns were the weight and adhesion.
I guess I'll give it a shot.
Thanks
Old 04-07-2007, 11:50 PM
Trotter's Avatar
Trotter
Trotter is offline
I put one on my stock black box, When I got the chrome box I pulled it off and stuck it on the chrome box and it's fine
[IMG]local://upfiles/24219/39BA0C159B254C86B9F980E4B64131E0.jpg[/IMG]
Old 04-08-2007, 11:51 PM
veniculum's Avatar
veniculum
veniculum is offline
I have the similar chrome "Harley Davidson" scripted band...it's been on there for probably 8 or 9 months...all kinds of temps, riding, etc, and it's still on there tight.
Todd
Old 04-08-2007, 11:54 PM
JayFromPa's Avatar
JayFromPa
JayFromPa is offline
I have the same one Veni has and put it on last nite. Just stuck it to the stock black box in my office over nite to let the adhesive get nice and sticky. It ain't goin' nowhere.
I do agree Moco could have come up with a better way of putting iton instead of some 3m tape.
dgbmvb
10-19-2016 07:33 PM
Soliton
08-21-2014 01:06 PM
shrini23
07-13-2012 11:04 AM
bikemiser
10-28-2011 12:16 PM
Micheletti
05-21-2009 10:37 PM
Quick Reply: Skull Battery Cover Band
