Can i keep stock plates on S&S Gear drive drive cams
Gear Drive Cams ...........
Did you check your crank run out before purchasing the gear driven cam's ?
Your crank shaft run out must be with in .003 for a gear drive, most newer model Harley cranks do not meet this spec ............
Be careful and make sure you check this prior to installation or you could end up with some really big issue's...............
Chain drive cam's are plenty good enough unless you are doing a monster build............ Just did cams myself, Andrews 48H..........
Hope this help's ??????????
Live Free = Ride Free...............
Not saying don't run gear drive but get what you will be happy with and save up than install something because the price was right.
Certified Mechanic.............
It would really suck to get everything a part and find out you can not even use what you have !!!!!!!!! Not may HD crank shaft's meet that spec for gear drive.
I personally would try and sell what you have and get the cam that best suit's what you have done to your bike and go with a chain drive set up.
I think you will be much happier with those........
Gear drive create's a lot of engine whine/noise and with out having your crank trued and pinned or welded there is no telling when it could ruin your day..........
I am not saying not to do it, do what you want but make sure you have all the information you need before you do it............
Yup I agree...........
Why not sell them and get what you want? Unless they have the lift,duration,ivo/ivc,etc you desire why install something that can make or break the way your bike runs and settle for possible disappointment?
stop! rethink
I just did the tensioner's on my 01. once you open this "can of worms" you are obligated to change inner/outer cam bearings, tensioner shoes or complete assy's, whichever your mech advises. you cant do inner bearings yourself based on the tooling to remove, and to install at proper depth. I opted to stay stock on pushrods so you will have to pull the rocker box covers and rockers/cc breathers and than you can go into the cam support plate area. all this for a set of "great deal lopey cams" is not the way to go. stay chain driven unless you are prior to 04 or have deep pockets.
