Painting Rims Question
Old 09-16-2014, 08:53 PM
ArcaneEdge's Avatar
ArcaneEdge
ArcaneEdge is offline
Default Painting Rims Question
Ok so after starting to paint the fenders and the tank and everything else I realized I didn't want to transform the entire bike and leave the mags looking like crap. So at really no additional cost I am getting my boy to paint my rims. Question is do you also paint the surface where the rotor touches where the 5 screw holes are or not? Please advise.
Old 09-17-2014, 06:14 AM
fugawi's Avatar
fugawi
fugawi is offline
short answer no, do not paint any surface that another surface will mount to.
Old 09-17-2014, 07:05 AM
ArcaneEdge's Avatar
ArcaneEdge
Thank you, that was my initial thought just wanted to put it out there and see others opinion. I will tape it off and stuff. Will clean it nice before taking it back to the shop at least.
Old 09-17-2014, 09:25 AM
4_stroke's Avatar
4_stroke
4_stroke is offline
May be worth replacing the bearings as well while its out.
Old 09-17-2014, 09:56 AM
ArcaneEdge's Avatar
ArcaneEdge
What about this thing on the rim, is there benefit to keeping it on there or can I just remove before painting? I think its to indicate its OEM or soemthing am I right?
Old 09-17-2014, 10:20 AM
USMC_ech110's Avatar
USMC_ech110
USMC_ech110 is offline
I believe those are the weights used to balance the wheel. I wouldn't remove them unless you plan to have the wheel rebalanced.
Old 09-17-2014, 10:30 AM
ArcaneEdge's Avatar
ArcaneEdge
You're right, that makes sense. I wont remove them, just paint over them. Thanks.
Old 09-17-2014, 10:40 AM
ArcaneEdge's Avatar
ArcaneEdge
You think I should? I looked at the other side and it looks fairly good. I purchased it used from Harley so I wouldn't know when it was changed last.
Old 09-17-2014, 11:08 AM
Ndfastln's Avatar
Ndfastln
Ndfastln is offline
For a cleaner look you could remove the weights before painting and then add Dyna-beads through the valve stem. You would be better off to powder coat the wheels, it is far more durable and will adhere much better.
Old 09-17-2014, 11:58 AM
ArcaneEdge's Avatar
ArcaneEdge
Thanks! I didn't know about Dyna beads, called my mechanic and they have it and can do it for me when I bring everything back. I will do that for a cleaner look like you said. I was going to powdercoat different rims because I actually don't like spokes but I spent WAY too much already in the bike doing everything I want to it. This is a more cost affective way than leaving it as they are and you can see from the pics above that isn't pretty. So I am sanding it down, cleaning them, bulldog, priming and my boy is painting them and putting clear coat on top.
Quick Reply: Painting Rims Question
