Need help finding fender struts for 79 Low Rider.
My dad has a 79 lowrider with i believe what is called a fat bob rear fender from CCI and he is missing a fender strut which i believe is also from CCI. The fender strut is unlike any i can find it has 2 mounting holes at the very back instead of the usual one hole, it also will need the turn signal holes. Even on CCI website i cant find these struts. Im trying to buy a new set for him for his birthday, thanks.
Received 4,925 Likes
Cburb88, I think this may be what you are looking for:
http://www.jpcycles.com/product/711-238
The issue you may have is it looks like the rear bolt was drilled in and is not in the stock location. It also looks to me like a HD Wide Glide rear fender put on a Low Rider, not a bad thing just might make it easier to find parts. Struts are going to be sold as a pair, so you can always relocate the bolt back to the stock location.
Neither of those are right, the bolt holes on the fender are factory not drilled. I can find the fender online new, same bolt holes as this one but no struts for it for some reason. The strut isn't drilled either that's how it came. I saw that v twin one but it's missing a bolt hole. Only 3 in the back 1 mount and 2 for turn signal. I need one that is 2 for the mount and 2 for signal.
