Brembo Front Calipers
Came off a 2015 Street Glide with ABS. Ran on my FXDB for a bit and are like new. Used DOT 4 fluid in them so if you planning to run these on a Dyna, they are ready to go for up to 14" Tbars. If you want to run them on your bagger, just flush with mineral spirits and bleed with DOT 5. Pads have lots of life left. Come with non ABS stock brake line off a road glide. Asking $250 shipped to the lower 48.
Mounting bolts, brake pads, brake line, and fittings included. All in great shape as you can see. I had to add spacers to center on my rotors so I suspect you'll have to do the same but I'm not familiar with your setup so you'll have to do some homework. Already has DOT 4 fluid in there so you won't have to deal with flushing out DOT 5.
