Large selection of FXDX parts, TC95 engine etc
See http://www.amazing-scenery.com/galle...2_09/index.htm for a gallery of images for these parts. Too many to attach to this…
Harley Davidson TC 95CI engine,
Additional items for engine; prefer to sale with engine above
Screamin Eagle Ignition Module 31778-00
Boss Dyna Leather bag set - #31WO Plain
Dyna black crash bar P/N 49007-90 (power coast black not chrome)
Dyna (99-05) leather tool roll P/N 91714-97A
Dyna FXDX quick release sissy bar and rack, black
Dyna 99-03 FXDX OEM Stock Tank (carb), vivid black
Dyna 00-05 FXDX OEM Stock 39mm adjustable forks
Kuryakyn Offset & 1-1/4” Magnum Quick Clamps (pr)
LeatherPro Large Trunk Bag, model #TB3900- Plain
Rifle light smoked 15” windshield for Rifle Roadster fairing
Mustang fender bib – 09+ touring
Mustang HD Dyna 1996-2003 Tripper Solo (76584) ,
Mustang HD Dyna 1996-2003 Tripper rear seat (76585)
HD OEM Deep Bucker Sundowner Solo seat for 1996-2003 Dyna (51933-01)
HD OEM Sundowner Passenger Pillion for 1996-2003 Dyna (51934-01)
Windvest SE Deuce and Springer chest shield, 14” model 10-1091C
- SOLD
- Removed from my 2000 FXDX when I installed a 120R engine
- 9,900 original miles and still running strong, zero issues with it.
- Serviced every 3000 miles by same dealship as it was sold and built.
- The timing and rocker box covers are chrome and are from the 120R -I kept the black versions off the original engine
- Engine built by dealership by the head master tech (Bob at Paradise HD in Portland, OR)
- SE 95CI big bore kit
- S&S gear driven S&S 585 cams
- Welded and trued crank
- SE Pro Kompressor heads p/n 17044-08
- SE Forged High-Compression Pistons p/n 22868-00a
- Manual compression releases
- See dyno sheet for performance using VH 2:1 exhaust, there is also an image of the engine in the FXDX (and items below)
- SOLD
- SE Pro Big Bore 44mm CV carburetor Kit p/n 27934-99
- Pro Big Bore intake manifold p/n 29635-99)
- SE Black Heavy Breather p/n 29098-09
- SOLD
- Good shape.
- This ignition system has retarded timing to allow use of higher than stock compression. Not for stock use (used with 95CI engine listed above)
- $275 plus shipping
- Complete set with mounting hardware, brackets and backs.
- Left bag is damaged from a low speed dump. Only scuffs and the bag holds its shape fine and isn’t dented or malformed. See pics for scuffs.
- If desired the left bag can be replaced or repaired by Boss. These are shown in the FXDX_tc95-1 image also.
- $45 + shipping
- Minor scuffs on right side otherwise great shape, see pics
- $50 shipped to lower 48 states
- Minor wear from use – see pics.
- SOLD
- p/n 52775-71 Chrome (wrinkle PC'ed black) mini lug rack
- p/n 52728-95 Chrome rail sissy bar upright
- p/n 52517-94 Smooth short rail backrest
- p/n 53834-00 Black power coated wrinkle detachable sideplates
- $500 plus shipping
- Great shape, no dents and paint is very usable.
- Minor paint flaws from use (typical stuff – see pics)
- SOLD
- Fully externally adjustable cartridge forks. Adjustable for preload rebound and compression damping
- Great shape, no damage.
- Will fit any 39mm fork setup and is a great way to get dual disk brakes on the front.
- Includes triple trees and full dual front brake setup including lines and handle bar control and ¾ axle.
- Setup for ¾ axle, but can be changed to 1” – currently fits’00-’07 XL models, ’00-’03 Dyna® models. Also can be used on late model FXR’s models. 32” length.
- Also have rear caliber as shown in pictures.
- Just add pegs
- $280 + shipping
- Excellent shape, only used for one 4000 mile trip so there is minor wear from use, see pics
- Have both keys – it is lockable…
- As new, mounted for a day.
- $20 shipped to lower 48 states
- Good shape.
- $150 shipped to lower 48 states
- Like new condition, only used about 3 weeks
- $100 shipped to lower 48 states
- $130 shipped to lower 48 states
- Great condition was used for a season.
- $85 shipped to lower 48 states
- $215 shipped to lower 48 states
- Handle bar mount, all chrome HDW
- Great condition, windshield is clean and hdw bright.
On the detachable sissy bar, I really only need the side plates, but I need to make sure they'll work on my '96. If the depth of the outside of the longest part of the bar is about 1.5" to the thin part of the bar where the luggage rack/backrest itself bolts to, I'll take the whole enchilada. I believe those are the right ones, even though the whole setup won't work on my bike. Does that make sense?
Still interested in whole sissy bar set up for my 2000 FXDX. You can email me @ mferrier76@gmail.com
Thanks.
Thanks.
