Dyno Charts This forum is for posting of your Dyno Charts. You will use a prefix to designate your Cubic Inches. When posting please include all model year, Cubic Inch and modifications in the thread title and in the body when posting your Dyno Charts.
103-113": 2012 FLTRU SE 110 engine with SE259E cams, SERT, V&H Power Duels/High Output exhaust, SE Heavy Breather.
Old 01-27-2017, 12:29 PM
Stick_FSMC's Avatar
Stick_FSMC
Stick_FSMC is offline
Default 2012 FLTRU SE 110 engine with SE259E cams, SERT, V&H Power Duels/High Output exhaust, SE Heavy Breather.
SE 110 engine with SE259E cams, SEPST, V&H Power Duels/High Output exhaust, SE Heavy Breather 58mm Throttle Body.
Max power 112.91bhp @ 5633.5 rpm, Max Torque 122.78 Ft/lb 41.22.6 rpm
This was a dyno pull only with a canned map. I know there is plenty more to be realized if a good dyno tune was done. It's a bit rich on the low end.
Old 01-28-2017, 11:49 AM
rigidthumper's Avatar
rigidthumper
rigidthumper is offline
Received 5,381 Likes on 1,584 Posts
"It's a bit rich on the low end".
And a bit lean everywhere else.
I'm curious. If you took the time to make pulls, while checking one cylinder for AFR, why wouldn't you adjust the map so AFR measured = AFR requested?
Old 01-28-2017, 12:09 PM
Stick_FSMC's Avatar
Stick_FSMC
The pull was done at a weekend event at Sacramento Harley Davidson. It was sponsored by the dealership and was free to any who wanted to run their bike on it. I didn't have any numbers on the bike since I put the cams in, so I put mine in line for a pull. This is what I got.
I do plan on getting a real dyno tune at some point, but just haven't done it yet.
Prior to doing the cam upgrade, I had SE255 cams in the bike. They only ran 97bhp and 117 Ft/lbs, So while I know there is still plenty of room for improvement, I was happy with what I had gained so far.
The bike pretty much sat unused over the winter starting right after the dyno pull because I was down with a knee surgery. Now that the weather has cleared up a bit and I am riding again, I will be doing a couple of auto tune runs. I want to see what I can do to clean up the tune on my own first.
Kingspoke
Engine Mechanical Topics
14
06-30-2022 06:11 PM
Skippy97
07-10-2013 09:26 AM
Colin1966
11-10-2012 08:41 PM
1sweetglide08
11-29-2010 02:21 PM
gsparesa
02-08-2006 06:50 PM
Quick Reply: 103-113": 2012 FLTRU SE 110 engine with SE259E cams, SERT, V&H Power Duels/High Output exhaust, SE Heavy Breather.
