Dyno Charts This forum is for posting of your Dyno Charts. You will use a prefix to designate your Cubic Inches. When posting please include all model year, Cubic Inch and modifications in the thread title and in the body when posting your Dyno Charts.
103-113": 2015 103 street glide
Old 02-16-2017, 06:24 PM
rsking45's Avatar
rsking45
rsking45 is offline
Default 2015 103 street glide special Andrews 48h pro pipe
Stage 1 A/C
Andrews 48 cam
VH pro pipe
Power vision
Not sure what to make of it.
Seems like maybe something was left on the table.Whatta think?
I havent been able to ride because ot the Freakin snow
Sorry about the pic.Not sure how to get it to view right
Old 03-09-2017, 12:15 AM
Bafflingbs's Avatar
Bafflingbs
Bafflingbs is offline
What's your fuel air ratio? I've always been told to keep it between 13.2 and 13.5/1. Your tune looks very erratic. Someone else here had a weird dyno result, and it turned out to be a cam miss aligned. (Off by one tooth)
Old 03-09-2017, 02:29 PM
rsking45's Avatar
rsking45
rsking45 is offline
I'm not sure what the AFR is. All I got from the tuner Was what I posted. As far as the cams, I know for a fact that the Are lined up correctly. I read that post about the cams off one tooth,he was lacking a lot of power. I Was thinking I should have ended up with a little more torque. Closer to 110
I have done so searching and found someone else with the same motor and cams and his dyno was very similar.
Bike runs good and pulls hard.
Hard to find someone who dynos around here that uses the tuners I have.
Herksuper
Engine Mechanical Topics
02-12-2015 09:51 PM
Buckinfitch
04-25-2014 10:07 PM
Tn.Heritage
01-20-2013 07:51 AM
Born2cure
08-26-2011 08:30 PM
RockerBob
05-16-2011 12:27 PM
Quick Reply: 103-113": 2015 103 street glide
