103-113": 2016 Low Rider S 110ci stock engine Bassani RR3 and PCV
2016 Low Rider S 110 ci engine. Stock engine with the stock hi flow air filter which every LRS had anyway. Added Bassani Road Rage 3 exhaust and K and N power commander 5 tuner. Custom tuned at my local dealer.
My first ever Dyno sheet post, I think it's about right. I believe stock horsepower is in the 80 hp and 100 torque at the rear wheel. I do know advertised dealer brochure torque rated it at 115.
I'm getting 90 hp and 113 for torque. Let me know what you guys think. Thanks everybody.
Rode the bike and it's got tons of torque down low and smooth power for revs above 3k rpm. It does back fire through the exhaust on deceleration from about 2000 rpm on down to close to idle. But I'd figure that might not be unusual for a straight through style exhaust. Usually I'd suspect the pipe to cylinder head gaskets as a possible leak that can create that issue but I bolted all this up evenly and torqued to specs.
Thanks for your help btw!
