Fault code P0505
Old 04-02-2010, 12:22 PM
Burleson64's Avatar
Burleson64
Burleson64 is offline
6th Gear
Question Fault code P0505
I've got an '06 Street Bob that has been punched out to 113'. It has the stage 2 kit and VH big radius pipes. I've been having problems with my EFI. I ran the Self Diagnostic and got the code P0505, and the part number 34327-06. I looked online for the part number and came up empty. can anyone give me any help on this?
Old 04-02-2010, 05:01 PM
hogbag07's Avatar
hogbag07
hogbag07 is offline
2007 electrical diagnostic manual
p0505 loss of idle speed control
a lose of idle speed control does not necessarily imply the IAC actuator or wiring has failed. It can be caused by a number of conditions such as a intake air leak improperly adjusted throttle stop or a misfiring cylinder.
diagnostic tips. leaking injectors will cause fuel imbalance and poor idle quality due to different air/fuel ratios in each cylinder.
Vacuum leaks in intake
Contaminated fuel
Excessive oil in crankcase (oil sumping )
TPS reading greater than 1% (possible throttle cable maladjustment) or battery voltage reading of less than 9 volts or a VSS greater than 0 will disable idle speed control
Loss of battery power to ECM pin 31
Good luck
Old 04-02-2010, 11:45 PM
Burleson64's Avatar
Burleson64
6th Gear
Contaminated fuel
Good luck
Okay, any idea where the best place to start would be? I'm pretty new to working on bikes.
Old 04-03-2010, 06:12 AM
hogbag07's Avatar
hogbag07
hogbag07 is offline
Do you have any warranty on the 113 build. Start with the easy things first check your battery is it fully charged. Then I would check your manifold flanges for a air leak by spraying some engine start around the manifold and listen for the revs to jump.
Old 07-29-2010, 06:21 PM
Handycam's Avatar
Handycam
Handycam is offline
How did this eventually work out for you?
I had the same error code and disconnecting and reconnecting the sensor wire fixed it.
Old 07-30-2010, 12:38 AM
LilBudyWizer's Avatar
LilBudyWizer
LilBudyWizer is offline
Which sensor would that be? The crank position sensor?
KillinItKeegz
06-13-2019 07:42 AM
minar
09-26-2018 04:04 PM
chaos5
09-26-2018 10:00 AM
dj skuzzy
04-05-2015 05:18 PM
WeaselHMC
09-12-2013 06:34 PM
Quick Reply: Fault code P0505
