Harley Davidson Forums
Harley Davidson Forums - Harley Davidson Classifieds - HDForums.com Photo Galleries - Create an Account - Harley Davidson News
Go Back   Harley Davidson Forums > General Harley Davidson Tech Forums > Electrical/Ignition/Tuner/ECM/Fuel Injection
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Electrical/Ignition/Tuner/ECM/Fuel Injection Having electrical problems? Need advice on ignition issues? Questions about a tuner? Have questions about a MAP or Fuel Injection? Find your answers here.
Sponsored by: J&P Cycles
Welcome to HDForums.com!
Welcome to HDForums.com.
Thread Tools Search this Thread
Old 06-16-2005, 02:15 AM
meatgrande meatgrande is offline
Default Alarm check engine light on new fatboy
I have a 2005 FLSTFI with 1200 miles on it and the alarm light came on once before. The dealer said I didn't press the turn signal switch in all the way and caused the fault code, so the y reset the fault. Yesterday, with my wife on the back I get another code fault. The first time I had my wife on the back too. With me and her together we are about 375 lbs total. I can't figure this one out, thanks in advance for any help you can give me. I am getting tired of driving 45mins o the dealer. I wonder if I can invoke the lemon law on a motorcycle if they can't fix it. Oh also the gas tank reads full all the time. Love the bike though.
Russ
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on HD Forums!
Old 06-16-2005, 02:37 AM
John TN's Avatar
John TN John TN is offline
Junior Administrator & Resident Troll Tracker
Default RE: Alarm check engine light on new fatboy
What was the first code and what is the second? Your dealer should/supposed to have mechanics that can fix it and that's what the warranty is for, or at least is supposed to be, get on them until they fix it right, as well as the gauge.
John TN
__________________
Old 06-18-2005, 10:45 PM
HDF Tech HDF Tech is offline
Try this proceedure to find out what's throwing a code
Be advised this only applies to the full serial data bikes, ie 04 and 05's The IM (instrument module) is capable of displaying DTC's (diagnostic trouble codes). Speedometer Self Diagnostics: The speedometer is capable of displaying and clearing speedometer, tachometer, TSM/TSSM and ICM/ECM Diagnostic Trouble Codes (DTC). 1- Turn Ignition switch to OFF & Run/Stop switch is to Run. 2- Push odometer reset button in & hold. 3- Turn ignition switch to Ignition and release odometer reset button. Background lighting sould illuminate, speedometer needle should sweep its full range and indicator lamps (battery, security, low fuel, check engine and cruise) should illuminate. The word “diag” should then appear. 4 - Push the odometer reset button once and you will see the selection menu "PSSPt" with the first P flashing. 5 - Each letter represents an area of the diagnostics module. The module that is flashing is the one you are going to check. To move from one letter (module) to the next, you push the odometer reset button one time. (from P to S to SP to t and back to P, etc.) P = ECM/ICM (Electronic Control Module [EFI] / Ignition Control Module [Carbureted]) S = TSM/TSSM (Turn Signal/ Turn Signal Security Module) SP = speedometer T = tachometer 6 - To get the DTC within an area of diagnostics, push and hold the odometer reset button in for 5 seconds and release. If there are any DTC’s the code will be displayed or the word “none” will appear if there are no DTC’s. Push the odometer reset button again to view additional codes if they exist. 7 - Record the codes. 8 - If DTC’s are not to be cleared, Press and release the odometer reset button. Part number of module will be displayed. NOTE: To determine if a code is current or historic, clear the displayed code by pushing in and holding the odometer reset button ( longer than 5 seconds) until 'clear' comes up. Release the odometer reset button. Turn OFF the ignition switch. Run your bike and shut it down then recheck the DTC’s again by repeating steps 1 to 9. If the code is current it will reappear. 9 – Press and release the odometer reset button to continue to the next module. 10 – Turn Ignition switch to OFF. -------------------------- DTC FAULT CONDITION MODULE B0563 Battery Voltage High TSM/TSSM B1004 Fuel Level Sending Unit Low Instruments B1005 Fuel Level Sending Unit High/Open Instruments B1006 Accessory Line Overvoltage Instruments B1007 Ignition Line Overvoltage Instruments B1008 Reset Switch Closed Instruments B1131 Alarm Output Low TSM/TSSM B1132 Alarm Output High TSM/TSSM B1134 Starter Output High TSM/TSSM B1135 Accelerometer Fault TSM/TSSM B1151 Sidecar BAS Low TSM/TSSM B1152 Sidecar BAS High TSM/TSSM B1153 Sidecar BAS Out of Range TSM/TSSM P0106 MAP Sensor Rate of Range Error Carb P0107 Map Sensor Failed Open/Low Carb P0107 Map Sensor Open/Low EFI P0108 Map Sensor Failed High Carb P0108 Map Sensor High EFI P0112 IAT Sensor Voltage Low EFI P0113 IAT Sensor Voltage Open/High EFI P0117 ET Sensor Voltage Low EFI P0118 ET Sensor Voltage Open/High EFI P0122 TP Sensor Open/Low EFI P0123 TP Sensor High EFI P0261 Front Injector Open/Low EFI P0262 Front Injector High EFI P0263 Rear Injector Open/Low EFI P0264 Rear Injector High EFI P0373 CKP Sensor Intermittent Carb P0373 CKP Sensor Intermittent EFI P0374 CKP Sensor Not Detected Carb P0374 CKP Sensor Synch Error EFI P0501 VSS Low Carb P0501 VSS Low EFI P0502 VSS High/Open Carb P0502 VSS High/Open EFI P0505 Loss of Idle Sped Control EFI P0562 Battery Voltage Low Carb P0562 Battery Voltage Low EFI P0563 Battery Voltage High Carb P0563 Battery Voltage High EFI P0602 Calibration Memory Error Carb P0603 EEPROM Failure Carb P0603 ECM EEPROM Error EFI P0604 RAM Failure Carb P0605 Program Memory Error Carb P0605 ECM Flash Error EFI P0607 Converter Error Carb P1001 System Relay Coil Open/Low EFI P1002 System relay Coil High/Shorted EFI P1003 System relay Contacts Open
Old 06-19-2005, 02:45 PM
Retired_Ted Retired_Ted is offline
I had the same thing happen on my '05 Road King - it was a burned out bulb. If you need to know how to clear the code, let me know.
__________________
Just Ride!!
Tags
2009, check, codes, davidson, efi, engine, fatboy, fault, fix, harley, injector, light, openlow, rear, reset
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
Vendor Directory
New Sponsors
Advertising Information - Harley Davidson Forums - Archive - Top
Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0
