Solenoid Clicks
Solenoid Clicks
I searched through the forums for this issue but didn't find it so I apologize if it has been visited. I was having earlier trouble with my bike starting. My starter relay would click but it would not crank the starter. It was intermittent. It worked at random times but it was a roll of the dice. I had replaced the starter and solenoid (a premature move) and that did not solve the issue. I recently swapped relays, and relay harness to include all of the ground connections. I also cleaned up all the ground points along with the battery cables themselves. Also the battery is fully charged and has been load tested. I also checked voltage at the solenoid connection when cranking and it showed no voltage drop. The manual says try and "Jump start" the solenoid. I am assuming that mean apply 12 volts at the solenoid which I did and I am still getting it to click but it won't crank the bike. It was fine before I messed with all the wiring but now I have an issue. Did it get fried in the process....? Hope that is not the case...
I got similar problem
I am new to this forum, not sure if I do this right. I got a 1998 sportster 1200 with similar problem, I can hear the starter relay click and the solenoid clonk but it does not turn the engine, however, if I put it in gear an turn the engine just a little so the flywheel moves it will start without a problem, So the battery does have enough power. Any suggestions?
I am not sure if you have the same issue however what fixed my problem was replacing the starter relay, harness, and all the connectors going to the starter and the battery. I cleaned up all of the points that the starter grounded to and have not had an issue since. I also read in other forums that the issue I was having, while not necessarily common but something that is nearly impossible to fix unless you get lucky like I said. So to alleviate any headaches in the future it is suggested that you install a push button directly to your starter and that way you can bypass everything from your start switch to your battery. You can pick up the buttons for about $40 or so....
Thanks Cal516 for your reply, I don't think my issue is power related as I do have power enough once I turn the engine a little by pushing the cycle in gear. Somehow that activates the starter. I was hoping someone had experienced the same issue, and found the solution. Spoke to a HD shop today and they suggested it being the starter coil that is getting bad, sounds reasonable, so I will try to find a new starter or solenoid. Again thanks for you reply.
Charge the battery and have it load tested, an auto parts store will do this for free.
Clean all battery cable connections, both ends of each cable.
While the cables are disconnected, remove the end of the starter solenoid and inspect the contacts, if they are burned or pitted, replace them.
You can find parts for these starters at a starter repair shop for a lot less coin than the dealer charges.
