2007 FLHX lost electrical
Old 10-22-2014, 09:56 AM
Zapped24's Avatar
Zapped24
Zapped24 is offline
Stage I
Default Please Delete
delete
Old 04-25-2015, 05:44 AM
emwolb's Avatar
emwolb
emwolb is offline
The first thing to check with a voltmeter an find out if you have the proper power from the battery. Then start checking your fuses. Chances are good that you have a fuse which has burned out, but I mentioned voltage/battery first just to go through that elementary check first to eliminate the stupid but essential place to start. Also might want to check your battery leads, especially the ground lead below the battery attached to a vertical bolt. I think it's to or through the transmission. And while you got your
Volt/ohm meter out, check continuity. Prolly just a fuse.
Doug Fogleman
EVO
14
06-04-2019 08:19 PM
coolbrze
05-13-2019 09:29 AM
kmitchellhd
03-31-2017 11:14 AM
Firechaser1141
10-20-2014 11:06 PM
freekdawg1200
10-13-2009 08:38 AM
Quick Reply: 2007 FLHX lost electrical
