charging issue.
Old 10-23-2014, 05:27 PM
Gandy's Avatar
Gandy
Gandy is offline
4th Gear
Default charging issue.
Need advice. 03 Dyna Superglide.
Battery went dead. Replaced with new one. Still not charging only about 12v at battery at most. Did all the stator checks, continuity and ground. It puts out 38v AC at plug at 2000rpm. Stator seems good. Replaced Regulator twice but still have the same problem. Checked all wiring and all good, regulator relay/switch/circuit breaker also replaced but It is still not charging. Do you guys have any suggestions before I replace the stator? Thanks.
Old 10-25-2014, 09:56 AM
grbrown's Avatar
grbrown
grbrown is offline
Received 2,851 Likes on 2,419 Posts
There are two Stickies at the head of this section about checking your charging system. Read and use them to find what is wrong.
tsmithopt
10-09-2019 01:44 PM
Miker7
11-28-2018 04:18 PM
Dyna02
06-19-2011 05:31 AM
rjs1223
08-13-2010 03:08 PM
ruff12
10-06-2005 01:37 AM
Quick Reply: charging issue.
