HD battery tender
Old 10-29-2014, 10:29 PM
unwwwired's Avatar
unwwwired
unwwwired is offline
Stage III
Default HD battery tender
I have an HD battery tender for my Road King. Is it powerful enough to use on my car battery in a pinch?
Old 10-30-2014, 06:14 AM
nhrider1's Avatar
nhrider1
nhrider1 is offline
Yes it will work, but it will take a long time to charge the battery. The HD tenders only charge at a 1 or 2 amp rate.
Old 10-30-2014, 09:22 AM
im's Avatar
im
im is offline
A tender is used to maintain a battery, not to charge.
Yes, it can be used to maintain a 12 volt battery.
If you are trying to charge a weak battery (not dead) it could take a few days.
Old 10-30-2014, 09:27 AM
TriGeezer's Avatar
TriGeezer
TriGeezer is offline
Received 29,275 Likes on 11,144 Posts
A rapid charger that you can get at Pep Boys, Walmart, etc...is a good investment for less than $50. Get one less than 7amps, and you can plug it into the Harley trickle cable. Helps for those times you leave it on accessory all night long with the radio on.
SeniorChief56
10-20-2019 01:32 PM
raygolda
Electrical/Lighting/Alarm
03-20-2015 08:33 AM
KBFXDLI
02-27-2009 09:10 PM
Blacklion213
11-07-2007 09:53 PM
jonny ebola
10-27-2007 07:00 PM
Quick Reply: HD battery tender
