Ultima Electronic wiring system for Shovelhead dual coils
I have an Ultima Elect module #18-530 which has only one pin slot for one coil wire. My problem is I have dual coils (DynTeck 5.0 ohms) each of my coils are dual spark plugged. My ignition is Dyna S single fire (DS6-2).
Link to the Ultima module image is below
My guess is the Dyna S Coil , (+12 Volt, switch wire) will be Ultima's Wire #6 (white with black strip) that goes into the #6 slot. Does it matter which coil I use? Or am I going to burn up coils or module?
thank you
