Rear LED turn signals are getting current but are dark
Upgraded the front and rear turn signals and the brake light to LEDs. Have tried this with zero, one and two load balancers, and everything lights up and flashes but the rear turn signals, which stay dark. But when I plug a bulb in, it lights up. Any ideas? I can't think two new turn signal units are both bad.
Got all of the equip for a HD dealer. The turn signals are Custom Dyanamics. The brake light and one of the load balancers is Kuryakin. I think the second load balancer is also Custom Dynamics.
I've installed both balancers under the seat in the harness headed to the rear fender.
I hope that helps
Thank you
FrankEGD
Don't know about your bike, but on my wife's '13 Sportster the polarity for both rear turn signals was reversed. Bulbs don't care, but LED do not like that, being unidirectional. I traced the wires back to the main connector under the seat. Got each connector apart, switched wires and re-assembled them. Worked fine ever since...
I hope that helps
Thank you
FrankEGD
I hope that helps
Thank you
FrankEGD
Try reversing the wiring to the LED's.
