2009 Hydraulic clutch switch
I need some help, I installed a Hydraulic clutch and installed the switch for it, I thought I had it plugged in to the proper pin, but not so, the bike will only start in neutral, and now my cruise control does not work, I get the red light only, never the green when I turn on the switch, did I wire it to the wrong pin? which pin does it go to? on the harness?
The wiring diagram shows a Black/Red wire going from the clutch switch to the TSSM.
The other wire is Black/Green (ground).
Make sure the colors match and that the terminal did not push back out of the connector when you snapped it together.
13RoadKing
Electrical/Lighting/Alarm
15
04-04-2017 10:27 AM
amike
11-13-2007 10:50 AM
