HELP!!Neutral OIL LIGHT ONLY- NO START 2012 ultra CVO
2012 Ultra CVO
Replaced Upper Chrome Fork Covers ( cow bells) which means, tire,fender, Ignition switch, accessory panel and forks have to come off.
Also adjusted Handle bars - Radio pulled out
Pulled out main fuse with ignition on to disengage Security- didn't work- like to never shut off.
Now when I turn switch on I ONLY HAVE OIL & NEUTRAL light come on, NO DASH, TURN, FUEL PUMP noise ect. come on.
I HAVE:
1) Checked ALL Fuses- OK
2) Replaced Key FOB and Security FOB Batteries- OK
3) Rechecked ALL connections I had apart and the ones I didn't- OK
4) Tried the ON-OFF, ON-OFF ect. to get into PIN RESET - NOTHING
5) Pulled Main Fuse again- Siren ONLY- NO 4 WAYS ect. come on
IT seems like it is a Security MODE I don't know how to get it out of, ALL HELP is APPRECIATED!!
I HAVE:
