Left Turn signal not right
Old 02-13-2015, 09:04 AM
RBolig's Avatar
RBolig
RBolig is offline
3rd Gear
Default Left Turn signal not right
Guys, I hope you can help. I have a 2000 FLHTC, and when the bike is running and moving, the left turn works intermittently--bulbs all work.
But, when the bike is not moving, the Left turn works as it should--whether the engine is running or not running. I can move the handlebars, and there is no affect (they keep working).
thoughts?
Old 02-13-2015, 05:40 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Dan89FLSTC is online now
Received 8,477 Likes on 4,602 Posts
Front, rear or both?
Old 02-13-2015, 06:04 PM
Harleycruiser's Avatar
Harleycruiser
Harleycruiser is offline
I would start by replacing the bulb, I have seen broken filaments that touched but with vibrations did not work.
Old 02-13-2015, 06:07 PM
Harleycruiser
Oops, broke the golden rule, should have seen Dan's post, always ask a question for one post new members:-0
Old 02-13-2015, 08:56 PM
RBolig's Avatar
RBolig
RBolig is offline
3rd Gear
Both bulbs blink.
I can change the bulbs a see what happens, but I figured they were ok because even the vibration of the bike running they still worked. I thought maybe the TSM????
Randy
Old 02-14-2015, 04:40 AM
RBolig's Avatar
RBolig
RBolig is offline
3rd Gear
Well, I changed the bulbs, and I am still having same situation. Any suggestions?
Old 02-14-2015, 07:38 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Check the connector on the TSM, make sure there are no pins that are pushed back into the connector (the violet wire is the left turn signal).
If that is ok, you might want to get inside the fairing and check the connectors, and also see if you can duplicate the problem by moving the harnesses around.
Old 02-16-2015, 08:28 AM
RBolig's Avatar
RBolig
RBolig is offline
3rd Gear
Thanks, I'll give that a try.
Old 03-01-2015, 12:23 PM
RBolig's Avatar
RBolig
RBolig is offline
3rd Gear
Well, I checked the bulbs and the connections (both in the fairing, and at the TSM). No change. I replaced the turn signal switch, and also checked the wires where they go through the dimple under the clutch perch on the handle bars, just in case one might be pinched--no change.
I guess the only thing left is the TSM????
Madness04
EVO
42
09-08-2013 07:51 PM
hadesvi
03-13-2012 01:42 PM
oliver99
07-29-2010 12:11 AM
Dr.Cool
05-10-2007 11:13 PM
cartman18
07-18-2006 02:14 AM
Quick Reply: Left Turn signal not right
