2005 RK / Head Light Wire Burning, Shorting
Good Day,
A year ago I installed a set of 16 inch Caralini Apes. I received wire extension kit with it. I matched up wires, soldered, heat shrank and re ran wires. Reconnected Deutch Connectors and all was well. But now on 3 occasions I have had the main lead for headlight low beam burn out. I usually just cut off old deutch pin, stripped and reattached another. I figured I crimped pin improperly. Well 3 times a charm. What could be causing this to keep happening? Bad Solder? Bad Ground? Bad Wire from Kit? I have attaches photos below. Any input would be great!
Good Day,
Are you using the proper tool?
No Sir, I infortunately don't have a Deutch Crimper.. I used needle nose to bend the clips on Deutch Pin. May have to use a shop to crimp properly
I have 40+ years in high tech and military electronics (mostly Power Electronics). I've seen lots of failed power connections...and that one has definitely failed. Make sure the soldered connection is good before you crimp.
I agree with the others, that melted insulation was caused by a poor crimp, which causes a bad connection, resulting in overheating due to the high resistance.
There is no soldered connection in a Deutsch connector.
