2003 FXDWG Left Turn Signals Inop (Running Lights On)
#31
Last night, before I went to sleep, I took the black square (on the right in the photos I posted) and took it out of the line. I was able to plug the cables together. No change in the left side. Everything else still worked as it did when the box was part of the circuit.
The left turn signal wire is violet, see if there is a violet wire in the connector, unplug it, and check for voltage on the female side, it should be 12 v.
I see a violet wire going to that wire nut, check that see if it is 12v when the left turn is on, off when the turn is off.
You say you cant find where that wire goes?
Even with leds in the rear the turn signal should come on and not necessary flash. It will start as normal then start flashing real fast to let you know it has a bulb out.
Message me your e-mail I will send you a schematic.
Or my e-mail is on the bottom of my signature.
wein77
02-26-2021 09:13 AM
Kevin714
03-08-2013 07:54 PM
