Headlight wiring
Old 04-26-2015, 02:57 PM
Jimmy Alcumbrack McDaniel's Avatar
Jimmy Alcumbrack McDaniel is offline
Stage II
Default Headlight wiring
Hello everyone...wondering if anyone could help. I know a little about electrical and am fine doing the work myself...but little things can stump me in my tracks. I am in the process of getting rid of alot of things on my 2001 XL1200 Sportster, basically ratting the bike out. I got rid of my horn/hi-lo beam switches and looking for a way to get the headlight to run continuously. I looked up the wiring diagram to find a solution, but can't figure out.
If anyone has any ideas or have done this very thing...I'd love to hear what you got.
Thanks,
Jimmy
Old 04-26-2015, 04:57 PM
jtarter's Avatar
jtarter
jtarter is offline
Do you have an ON/OFF switch for your light? My light is always on, if the bike is on. So what are you asking?
Old 04-26-2015, 06:56 PM
Stage II
I never did have a switch and it was always on, but I think now that I got rid of the low/hi beam switch...that's why my light will not work. So the light has 3 wires....one from the fuse box and the other 2 from the switch (which I do not have anymore). I'm wondering if those wires are not connected to anything is the reason my light doesn't work...or I need to go with a new headlight that is only a low beam.
Old 04-26-2015, 08:13 PM
Harleycruiser's Avatar
Harleycruiser
Harleycruiser is offline
What did you do with the wires that were hooked to the high low switch, do you think that might have something to do with the light not working:-)
Old 04-27-2015, 06:09 AM
Mchad's Avatar
Mchad
Mchad is offline
Received 3,510 Likes on 2,133 Posts
As said, if the light stopped working after you removed the switch, then more then likely that's your problem. Get a multimeter, find the wire that supplies 12v when the bike is on, and try jumping it to the other two wires, one by one, seeing which activates the low beam. Once you find it, solder them together and waterproof heat shrink it.
I don't see the weight saving vs. the lack of a high beam switch being worth it. You also may risk never passing a state inspection again if you plan on doing that...
Old 04-29-2015, 04:23 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Dan89FLSTC is offline
Received 8,497 Likes on 4,612 Posts
A guy with zero electrical knowledge, ratting a bike out...you mean turning it into a POS.
Here`s what I think you should do:
Put the bike out of it`s misery, take it out and shoot it.
Old 04-29-2015, 06:28 PM
Harleycruiser
Dan it seem 1\4 of the post in here are guys who want to "simplify the wiring," and 1\4 the post are "PO butchered up the wiring how do I add turn signals"
snuff2000
Electrical/Lighting/Alarm
07-12-2019 05:44 AM
USAproud
05-26-2018 08:29 PM
Redemption
04-10-2012 09:36 AM
RandyDowdy
09-08-2010 06:42 PM
j.m.s.
08-30-2010 10:56 PM
Quick Reply: Headlight wiring
