Engine will not turn over
Old 05-26-2015, 08:06 PM
TSheff's Avatar
TSheff
TSheff is offline
Received 3,340 Likes on 1,548 Posts
Originally Posted by 1911guy
Ok I put my sportster in 1st gear and pushed it several feet. I then attempted to start it and what ya know? It fired right up just like always!!! ?? Go figure. Was the flywheel and starter locked ? Something was drawing the juice but not allowing it to start ?
What was drawing was the starter engaged on the flywheel. If you rode all the way home and when you tried to start it never clicked, it was engaged the entire time. The rotation of the engine/flywheel should have disengaged it. I would inspect the starter chances are you may have damage. Don't want to be left in the middle of nowhere.
Old 05-26-2015, 08:21 PM
1911guy's Avatar
1911guy
1911guy is offline
3rd Gear
Default Engine will not turn over
That certainly sounds possible but I stopped twice before arriving home and shut bike off both times and it started each time. Would the starter not disengage the flywheel each time?? I certainly don't want to be stranded over this. This is my main source of transportation. How much to replace the starter ?
Old 05-26-2015, 08:25 PM
Harleycruiser's Avatar
Harleycruiser
Harleycruiser is offline
Yea the starter was locked on the ring gear. I would pull the primary and see what is going on, look for any debris any thing that could get stuck between the two, anything loose, etc.
Old 05-27-2015, 04:54 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Dan89FLSTC is online now
Received 8,476 Likes on 4,602 Posts
Even if the starter pinion gear was stuck in the ring gear, the starter solenoid electrical contacts would not stay connected, the solenoid shaft is two piece, not like the older shovelhead solenoid.
Old 05-27-2015, 10:45 AM
TSheff's Avatar
TSheff
TSheff is offline
You are quite correct, I was just referring to the pinion gear stuck on the ring gear not allowing proper operation, but still allowing draw when the switch was pushed. I would still expect some damage to one or the other.
basu
04-18-2017 06:23 AM
kareengas
02-04-2016 08:59 PM
jblass
12-24-2014 04:53 PM
drp.deluxe
03-02-2014 09:19 AM
jacknthebox
07-24-2010 11:12 AM
Quick Reply: Engine will not turn over
