Wire Pin Terminal Size?
Old 11-01-2015, 01:37 AM
SnoRider's Avatar
SnoRider
SnoRider is offline
Default Wire Pin Terminal Size?
I have a 2011 FLHRC. I want to make up a wire for my passing lamps so they stay lit when high beam is on. I will remove the yellow wire pin from the passing lamp connector (white 4 pin connector that goes to passing lamp switch) and insert the pin on the wire I am making up. I will then route the new wire up to the orange with white stripe fender tip light wire that comes from the headlight and connect to it with a spade connector. I figure then I don't have to cut the original wiring.
Anyone know where I can get the pin terminal that is used on the yellow wire and what size it is? How about size of the spade? Does this all make sense?
Old 11-01-2015, 07:23 PM
SnoRider's Avatar
SnoRider
SnoRider is offline
No one?
Old 11-02-2015, 01:01 PM
madsonp's Avatar
madsonp
madsonp is offline
Don't know the pin size but have you seen this ? http://www.harley-davidson.com/store...re-harness-kit
Old 11-02-2015, 02:47 PM
SnoRider's Avatar
SnoRider
SnoRider is offline
Yeah, $29.95
Old 11-02-2015, 02:54 PM
TriGeezer's Avatar
TriGeezer
TriGeezer is offline
Received 29,273 Likes on 11,143 Posts
Originally Posted by Jessem
Yeah, $29.95
...and?
Seems like good deal, versus your labor and reliability of making all those connections.
Old 11-02-2015, 03:08 PM
SnoRider's Avatar
SnoRider
SnoRider is offline
Its just one wire. It has the pin on one side and a male spade on the other. Just take the yellow wire out of the connector and tuck it, plug the new wire in and connect the spade.
zivkos
2018+ Softail Models
03-10-2019 09:29 AM
SnoRider
11-02-2015 02:48 PM
chipguy1
08-21-2013 07:56 AM
Dumass
05-12-2008 10:52 PM
HDF Tech
Electrical/Lighting/Alarm
12-12-2005 08:16 PM
Quick Reply: Wire Pin Terminal Size?
