Trickle charger connection
Old 12-23-2015, 01:35 AM
clackavosticus's Avatar
clackavosticus
clackavosticus is offline
Default Trickle charger connection
is it possible to connect a trickle charger to the heated clothing harness that's connected to the battery? Only this seems to be more accessible than the battery charging harness which I can't see on my 2014 FLHTK.
Or is there an easy way of accessing the battery charging harness?
Old 12-23-2015, 02:37 AM
OldEnuf2NoBtr's Avatar
OldEnuf2NoBtr
OldEnuf2NoBtr is offline
Received 1,811 Likes on 1,064 Posts
You should be able to access the pig-tail for the battery tender with out much of a problem. If it was routed incorrectly for whatever reason when you took possession of the bike, then just remove the seat and side panels and re-route it to a more convenient location. Mine comes out of one of the holes in the frame plate just behind the rear cylinder head and over the transmission on the FLHX.
Old 12-23-2015, 06:52 AM
Campy Roadie's Avatar
Campy Roadie
Campy Roadie is offline
Received 5,063 Likes on 2,501 Posts
It is possible provided the connections are compatible. What you should keep in mind is that should something go awry with the charger the clothing harness fuse is a higher amp than the battery tender harness.
Like Know Better says, find or install the harness for the tender would be what I'd do.
Old 12-23-2015, 08:29 PM
YPD485's Avatar
YPD485
YPD485 is offline
I use the factory installed battery charging harness on my 2014 FLHTK for the battery tender plus and my heated jacket liner. Works fine for me.
d-streetglidr
12-01-2013 08:18 AM
deadman77
08-11-2013 07:48 PM
sharkey
08-22-2010 07:27 AM
tr6640
04-02-2008 11:23 AM
Billydj
VRSC Models
12-09-2007 03:48 PM
Quick Reply: Trickle charger connection
