Harley garage opener to smart door
I had the new Sears smart door with battery backup installed and my HARLEY opener no longer worked.
I hacked into the smart panel that has the button to open/close the door it also has the clock and temp display.
You need a volt meter, solder gun and the regular HARLEY receiver with the black and red wire coming out of it. Now open the back of the Sears wall unit and put the test meter on ohms and touch the back (2 of the 4) pins of the momentary switch. That's the button you push to open/close the door. When you test the ohms it will always say OL (open line) If you have it on the right 2 pins, and push the button to open/close the door, the line will show some resistance, Not OL only for a second. Those are the 2 pins you want to solder the HD black and red wire to from the HD receiver.
Now mount the wall unit back on the wall and plug in your HD receiver and you should be back to using your High/low beam switch again.
Good job, I still have the old style openers so this isn't an issue for me, but I've heard where others have issues with the newer openers, and many of them solved their problem by buying an interface from these guys http://www.creativeaccesssolutions.com/index.php It's good to know however there're other cheaper alternatives that you can do yourself, do you have any pictures you could post ?
This is a pic of the 2 momentary switches that are under the open/close button
This is the back that I soldered the red and black HD wires to to bypass the Circuit board right to the momentary switch itself
I just bought and installed an HD garage door opener. I also had upgraded my garage door opener to a Chamberlain with the MQ feature. The HD garage door opener did not work with the newer opener, so Thanks Joe Cool for posting this thread. I followed your instructions on wiring right into the wall switch, and it now works.
big kal
05-26-2013 03:54 PM
Fire Guys Road King
04-08-2009 11:05 PM
