Need 2013 CVO Road Glide alarm help
I knew the batteries in my security fobs were getting weak and was working on the bike today when suddenly the alarm went off and I was unable to silence it. I don't recall how many cycles it went through, but it finally stopped. As should be the case, the ignition system was disabled. I went out and got new fob batteries. Even with new batteries in the fobs and no matter what I do, I cannot restore the system. It will not crank. I even tried to use the turn signal controls to disable the alarm, but I cannot get that to work either....the speedo digits don't come on as they should when I depress both turn signals immediately after switching the ignition on. I even pulled the main (40A) fuse for a brief period hoping that would reset things.......it did not. Any help would be greatly appreciated.
Did you try:
kill switch off
ign to accessary
Push both turn signals -- Security lamp should flash fast
press left turn sig to enter number and right turn to confirm and move to the next number.
Good luck
