04 FLH Cruise wiring vs 03
Old 02-16-2016, 06:37 AM
FatboysFatboy's Avatar
FatboysFatboy
FatboysFatboy is offline
Default 04 FLH Cruise wiring vs 03
Greetings and need a little help. Rebuilding an 04 EG and having issues with Cruise. I have 03 and 09 manuals and its 50 miles to Dealer. Can someone help me with the Cruise Module pin out. I have power, set, resume, throttle rolloff and ground signals based on 03 manual pin outs. Brake lights are good. I'm getting a 312 diagnostic code and am afraid the module is bad but before I spend $100+ I just want to check wiring again. I thing pinouts are the same but help will be appreciated.
03 Pin out
A} On/Off
B} Set/Coast
C} Resume/Accel
D} Throttle Roll Off
E} Ground
F} Ignition
G} Brake Signal
H} Eng Speed
I} Set Lamp
J} Speed Signal
Cruise Module is 70955-04. During diagnostics the light on tach turns green but when I try to do a lash adjustment it stays red. Probably a bad module but these things usually do go bad.
Thanks in advance for any help.
Old 02-16-2016, 07:34 PM
Vernal's Avatar
Vernal
Vernal is offline
Received 7,284 Likes on 1,903 Posts
From the 04 manual:
Good luck
Bill
Old 02-17-2016, 06:42 AM
FatboysFatboy
Default Thanks
Bill I appricate you taking time to send the info. 04 is same signals as 98-03. Wonder why the 70955-98 would not work as sub for 70955-04. Maybe tach signal or speed signal. All the others are 12v. Pretty sure my module is bad. Ordered a replacement off eBay so we'll see. If interested I'll let you know. Learned a lot about cruise during this. Exercise. Thanks again.
Old 02-17-2016, 07:00 AM
Vernal's Avatar
Vernal
Vernal is offline
Yes your Fault 312 Looks like a bad one Hope the new Module gets it going again. If not PM me and I'll email you the diagnostic pages for Cruise.
Bill
Old 02-19-2016, 06:01 PM
FatboysFatboy
Hey Bill, it was the module. Replace and it now working like a dream. Thanks for your help. Got a used unit from Az Cycles and it arrived today. They shipped fast and sell good used items.
Old 02-19-2016, 09:27 PM
Vernal's Avatar
Vernal
Vernal is offline
Glad you got it going again! I'll make a note about AZ.
Ride Safe
Jimdgreat1
01-03-2015 12:35 AM
CRAIGFARTHING
08-18-2013 08:19 PM
cp1
03-04-2012 09:17 AM
jbnl163
03-01-2008 05:18 PM
jbnl163
08-26-2007 07:13 PM
Quick Reply: 04 FLH Cruise wiring vs 03
