No Brake or Tail Light
I have a 99 Fatboy that I removed the rear fender for paint and the front LED turn signals to reposition for a batwing fairing. Since doing that I had an issue with the headlight, turn signals and rear tail light. I've since corrected the headlight and turn signal issue. (Front turn signal wire insulation was exposed)
Currently my problem is the brake light works in accessory but when I turn to ignition no brake light or tail light. I did have to cut the wires for the tail/brake light when I removed the fender. I put it back together with waterproof butt connectors and shrink wrap. I checked the dual filament bulb and it looks fine plus as I said the brake light works in accessory. Any ideas?
Thanks for the suggestions. Looks like all the connections at the ignition switch are fine.
I'm pretty electronically challenged so if you could tell me how to test the connection before the butt connection I'd really appreciate it. I assume you mean from the deutsch connection leading to the butt and not from the tail light leading to the butt.
