Alarm / I messed up
Old 05-01-2016, 08:50 AM
gernst's Avatar
gernst
gernst is offline
6th Gear
Default Alarm / I messed up
Good day Ladies and Gents,
I have ridden for a while, but far from knowledgeable.
Now I have messed up with my alarm system.
I have a 2001 Electra Glide, with the factory alarm system.
I have never used it and got a hair up my rump.
I put new batteries in the FOBs and engaged the alarm.
It armed and I tested it. No installed siren, the hazards flashed their pattern, and the bike did not start.
Now, it will not disarm. Neither FOB does anything. I have an owner’s manual, but have been unable to do anything to turn it off.
I have replaced the batteries, with the correct size.
No matter what I do, the bike does not react. Two quick pushes, a long press of the FOB button to get the bike and FOB interacting.
The alarm / key light flashes once every two seconds, indicating it still have the factory PIN.
And, I do not have this number.
Now, the fine folks at Harley are happy to put a new system in, but I really do not have the funds for this.
Any advice would be greatly appreciated.
Ernie
Old 05-01-2016, 09:17 AM
06 fxst's Avatar
06 fxst
06 fxst is offline
Seems like I remember a sequence of turning the ignition switch off and on 3 times and then the left turn signal twice. But you have to do it all in two seconds?
Old 05-01-2016, 10:06 AM
Backdraft161's Avatar
Backdraft161
Backdraft161 is offline
What year bike do you have?
If you use a key fob that you actually press the button. Press the fob two times quickly to disarm the system. Bike should start. By pressing the fob one long time it turns on the system and the flashers will flash 2 time
Hope this helps. Let me know if it does not work.7
Old 05-01-2016, 10:28 AM
gernst's Avatar
gernst
gernst is offline
6th Gear
It is a 2001. I have tried pushing both FOBs twice. I have also tried pushing the FOB button for an extended period time.
I am going to pick up a different brand of battery and try that.
Yes, I am grasping at straws.
Old 05-01-2016, 10:43 AM
Jackie Paper's Avatar
Jackie Paper
Jackie Paper is offline
Received 4,530 Likes on 3,783 Posts
Good day Ladies and Gents sounds too much like a stolen bike for me to throw in my two cent..or maybe I already did.
Old 05-01-2016, 10:51 AM
gernst's Avatar
gernst
gernst is offline
6th Gear
No, not hot.
Have to title and registration.
I am trying to keep it light to stop from screaming.
I just put $1,500.00 for new tires, 20,000 PMS and an inner primary leak.
I was hoping to head to Washington for Rolling Thunder, but that will change if I have to pay for a new security system.
Old 05-01-2016, 10:59 AM
rjg883c's Avatar
rjg883c
rjg883c is offline
You are a suspicious person? I am also always curious about this sort of post/problem. But just in case it is legit, and the OP really has the FOBs, I would suggest the possibility that the batteries might be upside down.
Old 05-01-2016, 11:08 AM
Ron750's Avatar
Ron750
Ron750 is offline
Received 16,515 Likes on 6,271 Posts
Yes, check this. Plus goes down, unlike most remotes. One long press arms alarm. Double click disarms.
Plus side down
Old 05-01-2016, 11:19 AM
gernst's Avatar
gernst
gernst is offline
6th Gear
I have tried the batteries in both position, buy yes, the positive side is down.
I even tried it with the batteries backwards.
I bought both the service and owner’s manual.
The service manual stated that you do not want to disconnect anything security related, with the system armed. So I haven’t. I don’t want to dig my hole any deeper.
Old 05-01-2016, 11:44 AM
larsfum's Avatar
larsfum
larsfum is offline
Couple of things. Is it near anything that may be tossing off radio interference (RFI)? Automatic doors, remote operated garage doors, cell towers, etc. Try moving the bike to another location, and then try deactivating the alarm.
From reading it sounds like the fob button has to be pressed two times very quickly. Others say that you have to replace the TSSM with a TSM if you cannot get it to disengage. Lastly there is this:
https://www.hdforums.com/forum/elect...roceedure.html
Quick Reply: Alarm / I messed up
