Cycle Electric 50 AMP upgrade
I installed the Cycle elctric 50 amp stator and voltage regulator. however the kit did not come with a new circuit breaker or fuse, and my limited knowledge is that the stock breaker is a 40 amp unit. Should I get a new fuse or circuit breaker or is that ok?
Thanks
Jeff
Thanks
Jeff
Thanks
Jeff
Thanks
Jeff
I just legged my bike home with the voltage gauge at 12v , and I checked at the battery with a volt meter , and it is at 12v at 2k rpm, so I ordered the cycle electric 50amp kit with rotor, and regulator.
It should be here on Friday, and I will install it this weekend.
Did you use a rotor pulling tool or fake it?
