Street Bob electrical gremlin
Old 08-22-2016, 08:29 PM
truckermatt01's Avatar
truckermatt01
truckermatt01 is offline
Stage III
Default Street Bob electrical gremlin
Hey guys, new here, been cruising the forums for a fews days trying to get some answers so I figured id ask...last week the red key light came on so I shut down the bike started it up and it went away....few days later it came back on and had the bus error but then would go away on its own.. then my "6" light would not come on while in 6th, then that fixed itself and then one time I lost the speedo and got a batt, engine, key light came on real fast and then went away. I looked up the codes and this is what I got...
P0131
P0151
U1097
U1300
U1301
U1255
U1016
U1064
Old 08-22-2016, 08:41 PM
QC's Avatar
QC
QC is offline
Received 19,786 Likes on 9,863 Posts
Welcome to the Forum from Colorado!
What are we working on? Year, model, mods, mileage, etc.
Check your battery connections for proper connectivity. Check under the dash for crud, corruption, and corrosion around the main harness and the ignition switch harness and the switch itself.
Old 08-22-2016, 09:08 PM
truckermatt01
Stage III
Sorry guys, its a 2008 with 8000k It has vance and hines pipes with a fuel pack? tuner on it. I just picked it up a few months ago. I pulled all the fuses and cleaned them because there was some crud on it, took the ecm out and plugged it back in because it looked cleaned, took off the dash and made sure all the connections were clean and tight. Didn't really start following any harnesses because I don't really know what I'm looking at.
Old 08-22-2016, 09:12 PM
QC's Avatar
QC
QC is offline
Here's a link to the codes.
https://www.hdforums.com/forum/softa...des-dtc-s.html
How fresh or old is the battery. If you haven't, make sure you check all the grounds for good connections
Old 08-22-2016, 09:22 PM
truckermatt01
Stage III
Not sure on the battery age but it cranks good and I keep it on a tender if that means anything, Ill have to go over all the grounds tomorrow, thank you I really hope I can figure this out. Gremlins are the worst
dan chow
08-13-2018 11:03 AM
smallhog
05-03-2013 12:38 PM
dreamcatcher2007
06-27-2011 10:39 PM
eno50
08-25-2009 08:50 AM
SportyPig
07-18-2007 06:25 PM
Quick Reply: Street Bob electrical gremlin
