Re-wiring Aux Driving Lights
My 2014 Low Rider has aux driving lights (HD Aux Lighting Kit 68605-08A) that were installed as per this diagram:
I would like to re-wire this setup for a couple of reasons. The most important being that I'm installing a Power Vision tuner and need access to the diagnostic port that this lighting install used for the aux lights. Secondary to this, I would not be unhappy if the lights would operate with both high and low beams instead of the current low beam only.
Is there a way to power an accessory not using the diagnostic port, that will not cause Canbus errors, and allows for ignition switched power?
Try one of these:
http://www.harley-davidson.com/store...11-69200442--1
http://www.harley-davidson.com/store...re-harness-kit
or check out this thread.....
https://www.hdforums.com/forum/dyna-...-lights-2.html
(post #5)
you might find the answer in there somewhere.
(post #5)
I got one like this for my Slim:
http://www.harley-davidson.com/store...on-upgrade-kit
You might have to cut the connector off your lighting harness and use the butt splices?
I used mine to connect non CanBus compatible auxiliary lights. Works perfectly.
TriGeezer
19
10-06-2018 03:08 AM
tabone75
09-17-2008 08:10 AM
