Dyna Electric System Troubleshooting
Hello,
I have an electrical problem, when turn ignition on, the headlight is working, but the speedometer does not illuminate. I am using dyna electrical diagnosis manual to troubleshoot. I proceeded up to ODOMETER SELF-DIAGNOSTIC INOPERATIVE part. There I have to measure resistance between DLC terminals.
The question is, when I unplug the component (speedometer, ECM, LHCM, etc.) and measure resistance should I plug it back before unplugging another one? The manual does not state that, but logically thinking I should plug speedometer back, before testing ECM. Correct?
As usual, I will answer my own question.
So basically there is no difference whether during test you plug the component back or not, because its resistance is several hudred times bigger (10-50 kOhm) than other components with terminating resistance (120 Ohm) and until that component is good, the difference in total resistance of full chain will not much differ.
Managed to fix this problem, have a speedometer light on, can check DTCs etc. Have a simple question.
Currently starter cranks the engine, but there is no spark. In terms of DTCs I have one which says turn light circuit open and fuel gauge not connected. Could this be the case, why there is no spark?
Should the motorcycle start if the speedometer illuminates, o there is some electric logic which does not allow to start the engine.
Thanks
Thanks
Going to need at least a year on the bike to be more helpful. Model would be helpful too...
Did it run before you started messing with the speedo light? Just because the speedo light illuminates doesn't mean the rest of the ignition system is getting power. There are usually different ignition hot circuits so if you blow the fuse on your lights you can still make it home. And as skinman13 asked have you made any modifications to any of the electric or ignition systems?
aamax
10-25-2005 11:49 PM
