Tail light lens replacement?
I bought a new blue dot tail light lens,because mine is cracked. Today I went to replace it and unscrewed the two screws. The whole assembly came off? I tried to separate the old lens but it would not come apart. Iso this glued or just stuck due to age? Has anyone replaced their lens?
Thanks
Thanks
http://partsfinder.onlinemicrofiche....=43&c=0&d=2001 FXDL DYNA® LOW RIDER (GD) TAIL LAMP W/ REAR TURN SIGNALS
Part #4 is a J-nut. Part #7 is the base
IF it is OEM, you should be able to gently rock the lens off the base once you remove the two screws holding it on. You may have to pry it and since you are replacing it anyway, I wouldn't worry about breaking the lens. The lamp harness in the lens disconnects from the printed connector board in the base and the base stays mounted to the fender.
Mr. Wizard
11
06-15-2019 01:28 PM
