I have an older Custom Dynamics turn/brake signal flasher module and LED tail light and turn signals. It is all plug-n-play with incandescent front turn signal bulbs. When I installed LED turn signal lights in the front, I had to install a load balance to get the turn signals flashing correctly. I had to modify the wiring to install the balance resistor.
