ECM fuse blowing
ECM fuse blowing
Hello
Fuse does not blow until bike is running a few seconds. When ignition is switched on and kill switch is turned on all is good...the bike starts as normal, runs a few seconds then blows the fuse. I removed the power commander V and it runs as normal but that could just be because some wires got moved...guys where do I start
larsfum's idea is a good place to start. Other than that gfriend it's always good to state the year and model of bike you're working on. This site is great, go to the search tab, type in what ever year your bike is and style, eg 2014 Touring, then look for wiring diagrams.
https://serviceinfo.harley-davidson....uring&id=56344
Update PCV is out of the system...fuse no longer blows but I am getting no spark on front cylinder..plugs replaced swapped wire and it works on another bike... Coil ohms out good but since primary is so low I am going to check it on another meter sorry guys bike is a 2008 softail deluxe
update
Replace the coil and she is alive!!!
blueangel73
09-20-2017 03:50 PM
