Stuck!!!
Stuck!!!
Hey folks this is my first post and I hope it finds u all well! I have a '14 softail slim that I'm tryin to convert to led and separate the brake light from the blinkers on the rear. Has anyone done this? Problem I'm having is the brake and blinker r in the same wire and I want to put the brake light in the license plate axle mount and hide the blinkers else where... any experience or ideas would b greatly appreciated!!! Thanks!!!
I have a 16 Slim S . Under the seat is 3 connectors together, one goes to the l/r light and one goes to the r/r light. the center connector feeds the license plate light. In the center connector, 3 wires into the connector, and 2 out, the center wire is the brake light feed. If it's the same as mine, that's the wire you are looking for.
