six gear green light
I have a 2008 Harley Davidson electra glide ultra classic flhtcui bought from texas?
i have a 2008 Harley Davidson electra glide ultra classic flhtcui bought from texas and shipped abroad .whenever i go to 6th gear i have 6th gear green light on dash, cruise working fine as well as signal lights but security light on.
i have a code b1154 which is shift interlock switch
took out clutch lever and handlebar left chrome housing but couldn't find any switch there .something is wrong here.2 month ago everything was working good and no problem at all.this happens a month ago and still same problem.
it happens sometime that i go into 6th gear but no green light on dash nor security light nor cruise working,
any suggestions .i cant find that switch
thank you ill try it today
Hi again update.
i took off the left housing and found that the previous owner took out and deleted the interlock switch and just kept the wires seperated.
what is going on here?
when cruising no security light no 6th gear indicator and no cruise ctrl . Whever the sec light in on i have 6th gear light and cruise working fine. Rtrved code b1154
Switch interlock wires
Hi again update.
problem solved
i removed the front fairing and found the black/red wire pinched and touching ground.isolated and everything working fine
thank you
Hi again update.
Hi again update.
problem solved
thank you
