Starter relay issue
Starter relay issue
I got my 02 Ultra Classic last year. The previous owner or someone had placed a makeshift get it home button on the starter. IE: push button switch, wired to the positive on the starter and plugged into the connection where the start button wire should be. I removed it and put a get it home switch on the end of the starter. Works just fine but not being able to start it normally has been driving me crazy. After a lot of research, I traced the problem to one wire on the starter relay. Tested the relay, works fine. The issue I found is the relay was not grounded (pin 85 on relay). The tan and green wire on pin 85 is connected to the TSSM, position #9. Wiring diagram shows it is for the start relay connection. My fix was to remove the tan/green wire from the relay socket and tape it off to eliminate it from grounding to anything. I then put a new wire in its place and grounded it to the frame. In doing this, the relay works properly and the factory push button switch works as it should. I have checked turn signals and flashers, radio and security system. Everything is working as it should. Does anyone see any issues with what I have done? Your input is much appreciated.
Safe travels.
Safe travels.
Safe travels.
Safe travels.
