LED Lighting Basics and Building Lights (Pics)
Old 10-29-2005, 12:58 PM
HDF Tech's Avatar
HDF Tech
HDF Tech is offline
Default LED Lighting Basics and Building Lights (Pics)
Here's the basics needed to set up your LED lighting...
A source for LED units... HERE
A link with a lot of good info about different types of LED lights... HERE
If you want to build some custom lights, here's some input on it... HERE
[IMG]local://upfiles/2318/200D886EE4CD42E0B65CE59770D9D314.jpg[/IMG]
12 LED's Wiring Diagram
Notice that NO load resistor is needed. . Also notice the Anode and Cathode connections. The Anode is the LONGER lead. The LEDs MUST be connected in series, NOT in parallel.
NOTE: If using a light up switch connect the 3rd connection on the switch to ground
Multiple LED's Wiring Diagram
Similar LED Wiring Diagram
Here's a similar LED wiring diagram showing 4 seperate LED's (NOT connected). Notice the load resistor that IS needed for each LED. For LED/load resistor information check out THIS SITE. . Also notice that the Anode on the LED is connected to positive. The Anode is the LONGER lead. NOTE: If using a light up switch connect the 3rd connection on the switch to ground.
LED Wiring Diagram
Notice the load resistor that IS needed. Also notice that the Anode on the LED is connected to positive. The Anode is the LONGER lead.
Source: http://www.oznium.com/forum/topic3633
Old 08-05-2010, 03:10 AM
moyaled's Avatar
moyaled
moyaled is offline
Stage II
Default led innovative Lighting
Led Indoor Lights will creat an innovative revolution in the next 10 years .Led spotlights widely replace halogen as Indoor ,commercial Lighting due to high efficiency ,Long life and energy saving .
A 1W LED bulb can replace 10W halogen .that can say you will save 90% electricity in the same Lighting time if you install a LED lights .
Another problem is Beam angle of Led lights ,the Light angle is not so good as halogen .
And with the appear of Led globe Bulbs ,this problem quickly resolved .
And when we now go out and notice the Lighting ,1/3 of them are replacement by Led Lights .
Shenzhen moya Led lighting manufacturing wide kinds Of Led Lights for market request .( sales(at)moyaled(doc)com )
( www(doc)moyaled(doc)com ) .
Write by : Danny .
Old 08-13-2010, 04:41 PM
Harleypingman's Avatar
Harleypingman
Harleypingman is offline
Thanks!!!!
Old 12-02-2010, 07:51 PM
jerryw13's Avatar
jerryw13
jerryw13 is offline
5th Gear
Good stuff, thanx lots!
Old 10-25-2011, 03:49 AM
ahhwataday's Avatar
ahhwataday
ahhwataday is offline
How can you tell how many LEDs are needed when running in parallel and no resistor?
I dont know the specs on my LEDs but I have to use a 675 ohm resistor so my LEDs dont burn up
Old 10-25-2011, 03:10 PM
UltraNutZ's Avatar
UltraNutZ
UltraNutZ is offline
without the specs, you won't be able to figure out what type of load, how many LEDS, etc are required for a circuit. There are too many variables here; size, brightness, and then top that off with this scenario; out of 1000 LEDS made in a batch, 50 of those may have a different rating on them than the other 950 do. we would need the volt and amp ratings from the LEDS to figure this out for you.
Old 10-25-2011, 03:18 PM
UltraNutZ's Avatar
UltraNutZ
Old 10-26-2011, 04:00 AM
ahhwataday's Avatar
ahhwataday
Thanks
I tried using similar led specs
3mm blue led, water clear
Voltage:2.8-3.4v 20mA
Wave length 465-470nm
Brightness: 3000-3500MCD
View Angle: 25-30 degree
The chart shows for every 3 LEDs i need one 100 ohm resistor. Ill give it a shot and text it for an hour or so. See if they burn up or get too hot.
If the resistor gets too hot I could just add another LED correct?
Old 10-26-2011, 06:43 AM
UltraNutZ's Avatar
UltraNutZ
you're talking about dissipating heat here which correlates to wattage. Simply increase the wattage of the resistor you're using
Old 10-26-2011, 06:33 PM
ahhwataday's Avatar
ahhwataday
o alright, Im testing a 1/4 watt 100 ohm resistor with 3 LEDs. Its been about 45 mitures so far. They are still glowing but I havent felt for heat yet. (KNOCK ON WOOD)
Quick Reply: LED Lighting Basics and Building Lights (Pics)
