2009 dyna superglide key and switch
Old 09-16-2011, 02:42 PM
chugchug's Avatar
chugchug
chugchug is offline
Default 2009 dyna superglide key and switch
i have no power going to any of my lights,directionals,brake,headlite.The key and switched was damaged last fall by somebody in a storage area,in order to get some furniture moced in.they had to move my bike,the forks were locked..so instead of going and getting the spare key..they forced the forks and bending the pin that fits into the plate below the steering neck..it also ruined the switch and now..cuz i have not had the money to replace it,i cant run the bike there is no power to anything..im guessing that the damaged key/switch is finally broken.Is there an aftermarket key/switch assembly of good quality thats cheaper than the $200.00 Harley wants for a factory replacement? Does anyone have a good used one for sale?
Old 09-20-2011, 08:37 AM
UltraNutZ's Avatar
UltraNutZ
UltraNutZ is offline
check out Rob's Used Harley Parts. good guy and almost always has what I need for projects when working on other bikes.
http://www.robsusedharleyparts.com/
Old 04-13-2012, 03:08 PM
chugchug's Avatar
chugchug
chugchug is offline
Default Arrghhh!!!
I finally bought a new key/switch assembly and put it on the bike,But no dice..still no headlite,directionals,speedo,brake lites,the only lites i have are the nuetral lite and the oil lite..so i replaced the starter relay on a suggestion..nothing,it wont start kick over nothing! when i squeeze the front brake..the nuetral lite/oil lite go out..any suggestions..anyone..anyone
hawg50
04-07-2014 08:23 PM
$eventy2T
09-10-2013 08:38 AM
UT-rckr
07-18-2011 07:48 PM
masterblaster
12-11-2010 08:12 AM
Roadrocket
37
03-30-2007 08:06 AM
Quick Reply: 2009 dyna superglide key and switch
