Crane HI-4E/8-3100 (7-pin module wiring)
Old 05-27-2013, 05:37 AM
EVELdave's Avatar
EVELdave
EVELdave is offline
6th Gear
thanks Tony! I will start my changeover from fuel injection to carb tomorrow! The only thing i have to work out is the wiring! Think I've got it down in my head but hate to fry the HI-4E or something.
motorhead.english@live.com
Old 05-27-2013, 09:43 AM
EVELdave's Avatar
EVELdave
EVELdave is offline
6th Gear
got it Tony! thanks a bunch.
Old 05-27-2013, 09:53 AM
EVELdave's Avatar
EVELdave
EVELdave is offline
6th Gear
Default Conclusion!
This is what I conclude!
(C=Cannon/D=Deutsch )
C pin 1 to D pin 4
C pin 2 to D pin 1
C pin 3 to D pin 2
C pin 4 to D pin 7
C pin 5 to D pin 6
C pin 6 to D pin 5
C pin 7 to D pin 3
Old 05-29-2013, 06:28 AM
EVELdave's Avatar
EVELdave
EVELdave is offline
6th Gear
Guys, I threw this together and hope it helps out. the ignition harness will allow for simple plug-in of a single-fire or dual fire module/coil if you need for a change-out. Just remember the module and coil must be set for the same firing mode. I decided to do this as I don't want to mess with the harness under my FLH tank afterwords. This has NOT been tested yet but should be on by this weekend! Will let you know how the swapout works as I have both the Harley OEM ECM/coil as well as the Crane HI-4E and single-fire coil. Just in-case one ***** the bed I can just throw the other in.
Dave
Attached Thumbnails Crane HI-4E/8-3100 (7-pin module wiring)-crane-hi-4e-8-3100-7-pin-cannon-conversion-to-8-pin-duetscha.jpg
Old 06-07-2013, 09:10 PM
EVELdave's Avatar
EVELdave
EVELdave is offline
6th Gear
Default wiring diagram
guys, I made this up and it's been verified by Crane. Should do the trick.
Attached Thumbnails Crane HI-4E/8-3100 (7-pin module wiring)-7-pin-cannon-convert-8-pin-duetsch.jpg
Grego Sell (08-21-2023)
Ckjardine
09-29-2020 02:35 PM
TStephen
04-07-2016 07:48 AM
tonycap
EVO
05-10-2013 08:50 PM
jsbridgew
EVO
03-28-2011 08:05 PM
gabarnes28
10-08-2010 03:46 PM
Quick Reply: Crane HI-4E/8-3100 (7-pin module wiring)
