2003 883 not starting solenoid/relay ?
I have a 2003 sportster 883 over the winter I did some work, side mount plate and tail light,coil & ignition relocation, new builtwell bars new paint. When I got it all back together all seemed good all the lights worked and systems came to life but when I hit the start button I got NOTHING. I checked the (4) 15amp fuses in the fuse box, all are good. although when I was hooking up the tail light on the side mount bracket I did blow some of those 15amp fuses I replaced them right away and moved on.
? could I have blown the starter relay located by those fuses at the same time I blew the 15 amp fuse?
? how do I know if the starter relay is blown ?
? could one of my problems be the starter solenoid?
any help in diagnosing this would help greatly Thanks VC
