Ever had a new regulator/rectifier bad?
Old 08-08-2013, 02:44 PM
Jeff McKinney's Avatar
Jeff McKinney
Jeff McKinney is offline
Default Ever had a new regulator/rectifier bad?
07 EG,bike intermittently doesn't charge,will fall to batt voltage on gauge,then,starts charging again.The only thing I could find is the reg bleeding back battery voltage on all 3 stator side pins.Bought a new oem reg,plugged it into the batt side harness,and have batt voltage on all 3 stator side pins????
Stator test ok,20vac all pins 1k rpm,30v 2k etc,.2k ohm continuity between all 3 pins,no continuity to ground.
aces&8s
12-26-2018 09:03 AM
Diesel2
Electrical/Lighting/Alarm
07-04-2018 09:17 PM
t059736
05-21-2012 09:15 AM
byronrub
06-10-2009 12:07 PM
schlof
12-16-2005 05:35 PM
Quick Reply: Ever had a new regulator/rectifier bad?
