Regulator test doesn't agree with the sticky...
Old 04-28-2014, 03:21 PM
Jim Dawson's Avatar
Jim Dawson
Jim Dawson is offline
Default Regulator test doesn't agree with the sticky...
I suspected a bad voltage regulator and went through the procedures in the sticky for charging system testing. It says that if you have any voltage between ground and any of the three pins on the regulator's stator connector that the regulator is bad. Mine has 12 volts DC on all three pins. I replaced it with a new regulator and it has the same 12 VDC on all the pins. Replacing the regulator fixed the original problem but the sticky is from 2005 and must not be correct for newer regulators or I have a weird system.
Does anyone know for sure?
bartek2405
04-01-2017 05:51 AM
EasternSP
Electrical/Lighting/Alarm
10-27-2015 04:51 AM
dochawken
08-02-2015 07:33 PM
84 FLTC
Shovelhead
09-23-2014 09:35 PM
Jim Dawson
05-01-2014 04:35 PM
Quick Reply: Regulator test doesn't agree with the sticky...
