Have to push brake pedal HARD for brake light to work.
07-24-2014, 09:26 PM
I've been searching. Can't come up with the magic word combo...
Just like the title says. I have to push the rear brake to the point of lock up to get the brake light to illuminate. Any ideas?
Oh, 94 Dyna.
Thank you
07-24-2014, 10:12 PM
How good are your break pads I had to push mine pretty far before on my 93 till the light would come on then I replaced the break pads and it fixed it
07-24-2014, 10:16 PM
Pads aren't controlling the light...it's your switch or relay. Take a close look at rear brake assembly...Some thing's amiss...
07-24-2014, 10:22 PM
The switch is also controlled off pressure if the pads are almost gone it's not creating enough so it does effect it
07-24-2014, 10:32 PM
Maybe some, but not until you've got 'er down to the wood.
07-25-2014, 09:47 PM
Thank you,
I guess I was thinking that if it were the switch it would either work or it wouldn't. The brake pads are good.
I think I'm just going to,order the switch, change it, bleed, and see if that takes care of it.
07-25-2014, 10:32 PM
Change the fluid while you're at it....Brake fluid changes are widely ignored and are absolutely essential to proper brake system operation.
Usually when a brake light switch fails, it's because the fluid is dirty and the dirt gets in and fouls the switch.
07-25-2014, 10:40 PM
Get one at autozone..lifetime warranty
07-26-2014, 02:30 PM
Quote:
Originally Posted by
woody98237
For cryin out loud...If you don`t know what you are talking about, don`t argue the subject.
It is a simple system and not hard to understand, but obviously you don`t.
The brake pads have absolutely nothing to do with the operation of the switch.
It is a simple pressure switch, designed to close the circuit at a certain pressure.
The switch is bad.
07-26-2014, 08:29 PM
Thanks again everyone. I have a new switch on the way. I also ordered a MC cover seal and fluid. I was planning a fluid change at the same time.
